98 evinrude fuel problems
morrisusa
motor ran good,carbs loading up at idle.rebuilt carbs and now have to pump primer to keep from running out of fuel.I don't see or smell any fuel leaking.It runs/idles smooth until then.
Thanks
Just replace filter with a glass one.What could I have done?It revs up and idles until it runs out of fuel.Help
Daviet
Re: 98 evinrude fuel problems
You don't say what model you have but,have you checked the operation of the fuel pump?
SparkieBoat
check all fuel lines first..make sure you are not sucking air into the lines. Then The fuel pump sounds like your next thing...my money is on the fuel pump. Is it a VRO??
tashasdaddy
rebuilt carbs, float adjustment, pumping the bulb forces the needle open. or the vent not open on the fuel tank.
morrisusa
If a fuel line was sucking air,would it not leak when you pump up the fuel bulb?I will check the VRO.
Thanks
morrisusa
Just pulled hose of the top of the VRO,turned motor over,very little fuel coming out.
SparkieBoat
you still have not posted the model..but if it is a VRO and it is not pumping fuel..then that sounds like the problem as your VRO is also your fuel pump.
Good Luck Sparkie
