Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
If the timing was off due to a pin being sheared on the flywheel, how much work is it and would that be the cause of my problem? One plug is wet with fuel and the other is not?
So, with everything looking ok from outside -in what would be your advice on how to figure out what is causing the motor not to run and only firing on one cylinder?
