98 175 evinrude dies on acell.
bfishing
98 175 lemonrude will die on acceleration<br />idles good and runs topend great just dies right off idle. replaced all fuel line,bulb,filter, good compression,had carbs.worked on at two diff.shops,new stator,and just put new vro on this weekend as suggested by both shops. still have the same problem.
suzukidave
Re: 98 175 evinrude dies on acell.
have you checked to see if you are running on all cylinders (check the many posts here dedicated to power loss above idle on how to diagnose)
bfishing
plugs have all been replaced and look ok<br />comp.checks good <br />runs great on a hose but under load is a problem<br />thanks
