97 Yamaha Waverunner 1100
ROBDOG1
I have a 97 Yamaha Waverunner 1100, it used to run great and then late last year would not idle and it bogged down.
We had a remanufacured motor put in in July, we have run thru 30-40 gallons of pre-mixed gas and now it will not idle and it boggs down when you give it gas.
Could it be the fuel filter?
Can it be cleaned? and how hard is it change??
The owners manual says for the dealer to replacment?
Thanks
The Penguin
Re: 97 Yamaha Waverunner 1100
if all you did was install a new/reman motor and swapped over the components and are still having the same problem, my advice would be to start with the components.
rebuilding the carbs would be first on my list.
ROBDOG1
OK..........Found the problem my gas line on top of the tank came off so it was not getting any gas!!!!
Cheap fix
Thanks for all the help
