Re: 97' tracker force 120 hp
ok im following the trouble trail , adjusted 1/8 turn twice and noticed only a small drop in idle,I didnt want to adjust any further. While trying to troubleshoot the first issue noticed engine running just a little rough a slight shake.so earlier when adjusting idle decided to pull plug wires for change in idle #'s 1,3,4 was a slightly noticable miss but with #2 the idle didnt change just to make sure,I switched plugs and pulled wires and same thing happend is the CDM MODULE my problem? Hate to buy one and it be something else like trigger or $tator.This has been my biggest help.
