Just bought a 97 seadoo challenger jet boat. My first jet boat. It had sat for 2 years and when I went to pick it up the guy had hooked up the hose and started it up and it idled, however he hooked up the hose way before turning the engine on and turned it off way after turning the hose off. I guess this floods the engine with water.. Anyways before knowing about the water I put 10 gal of gas in it and put it on the water, started it up, and it had no power to it at all and sputtered out. trailered it home, and found the water.
I threw a bottle of isoheat in the has tank, pulled the plugs, and turned it over until there was no water shooting out. Couldn't get it to start, so I coated the inside with a little wd40 to sit overnight. Yesterday I had a couple hours and seemed to get some more water out of the engine and out of the exhaust but still couldn't get a start. I am getting spark, tried a little starting fluid in air box, tried a little fresh gas in cylinder, nothing. when I take a plug out and saturate a piece of paper with whatever is shooting out of the engine it doesn't flare up like you would think it should when you take a lighter to it.
Where to go next? drain all gas? take carbs apart? Take exhaust off and clean? Air intake? let it dry some more? any help would be greatly appreciated as this issue is probably time sensitive, thanks for your time!
