Re: 97 seadoo compression confused
Were you at WOT while it was cranking over? The best consistant results, spray a little fogging oil in each cyclinder, hold at WOT while cranking and you should get consistant numbers. As you put hours on your ski the compression should increase slightly as the rings seat.
