97 Sea-Doo GTS Cutting Out on Main tank
SunRed
Just got engines rebuilt and everything back together. Now we have a problem with it cutting out when turned on the Main Fuel tank after about 3 seconds. Runs perfectly when switched to the reserve tank.
Any thoughts would be GREATLY appreciated!!
SunRed
bigdaddypt
Re: 97 Sea-Doo GTS Cutting Out on Main tank
My guess is that the valve is clogged, or you have a leak in the line from the tank to the valve.
Why was the engine in need of a rebuild?
My best advice for you is to replace all of your fuel lines, fuel selector valve, and fuel water seperator. The gray fuel lines are known to fall apart on the inside due to ethanol in the fuel. This clogs up the fuel system, can lean out a carb, and can cause an engine to go...hence why I asked why it was needing a rebuild.
You can go to any auto parts store and get 1/4" fuel line, some stainless steel clamps and have at it...it's not expensive and is great preventative maitenance and will fix your issue.
