I have a 97 Rinker Captiva with a 4.3 lx Gen+mercruiser. I’ve been having tons of issues. Bought the boat last year and it ran great. Marina winterized anddstored for the winter. The drain plug was left in over the winter and there was some water in there when I opened it this year. At first launch it wouldn’t start, fuel pump died on me. Changed it out and she started. Great! First trip out it was very hard to get on plane. When I did manage to plane it out, top end performance was low. I seemingly lost like 400 rpm and close to 10kmh. Changed plugs which happened to have bpr5es installed which are wrong since the nvm cross is 6efs, drained the gas and refilled. Now the idle is low. Idling around 400 and dies. But if I hit throttle only, it would run. Did a compression test(only the cylinder being tested at the time had plug removed. My mistake) all cylinindets read between 140-150psi. Now I try and start it and the starter spins but does Not engage. Also the anti siphon valve seemed fairly difficult to desert the ball via blowing but I confess I’m not sure how difficult it would be to de seat. What am I missing? I’m getting pretty frustrated here. Any suggestions on next steps? Did I burn my damn starter out now to? I’m hoping it just got too hot or somthing...edit: to start it I’ve had to prime it via pumps of throttle only this year. I don’t hear the hum of fuel pump for a few seconds when key is on, however I can remove the wires and jump the oil pressure switch, the pump runs. Could my oil pressure switch be bad???
