97 Parker 17ft CC Gas Sending Unit Location
mpagano
Can't find the location of sending unit in my 17 CC Parker. Can anyone help?
Chris1956
Honorary Supreme Mariner
Re: 97 Parker 17ft CC Gas Sending Unit Location
The sending units are mounted in the gas tank. Usually there is an access port for them. Do you have any ports in the floor?
See if you can trace the fuel fill to the tank. There is often a hatch over the tank, that you may remove for access to the tank.
mpagano
the only access to the tank I have is for the ingoing gas and outgoing gas nothing else in that portthe other access port is in the stern only for access to the fuel filter and the pump-out, thats the only access to equipment. the previous reply I had was from a sea pro owner, he said that he had to cut out a hole with a jig saw and put a door over it. I would that but I have no way of knowing where the sending unit is located.
Chris1956
Normally the sender will be forward of the fuel pickup tube. Hopefully you can reach under there and feel for it.
