'97 OMC Cobra 350 EFI power loss at about 2700-3000 RPMS.
I have had the boat in the shop over a month and they first diagnosed it with a clogged fuel filter. As soon as I hit the water the same problem persisted. I can throttle up gently or quickly does not matter. When I throttle gently the boat engines creeps up to about 2700 RPMs power drops off and if I leave the throttle alone eventually the engine will power back up again. Also, after the power drops off I can here a squealing sound in the engine similar to a belt squealing but not as loud. The shop is now suggesting to replace the ECM. Very Expensive and I'm not convinced that is the problem. Any ideas?
