Re: 97 Monterey, standing water in ski storage compartment
My gf just bought a 97 Montery Montura 186. After it rains, there is always standing water in the ski compartment that is built into the floor. There is a hole in the bottom of the compartment but it's simply a hole in the fiberglass, not a drain or anything that I can clean out. There has to be a drain hole somewhere underneath but I can't find it and it's not visible to me. Any ideas on how to fix this issue? I've got a high speed air pump for innertubes and have tried blowing air into the hole to see if I can give a little pressure to blow out the clog. No luck, I just see air bubbles coming up through the carpet. I've tried going thru the main "plug" but it appears to just be an opening into the HUGE hull of the boat. So, if you have any ideas, let me know. Thanks, Greg
I'm the "guy" who just finished a deck/stringer replacement. My boat is a 1995 Monterey Montura 210. Have a look at these pictures. If you want to look through my whole restore thread, its in my signature.
In this picture..you can see the back of the ski locker has a drain hole. Is this the same hole that you have??
Or, do you have a hole in the bottom of the ski locker like these 2? The previous owner of my boat, put these holes here...who knows why. I have a built in ice chest under one of the the bow seats..it drains into the ski locker. The water should drain through the hole in the first picture..then under the gas tank, and back to the bilge. But after he drilled the hole in the bottom of the ski locker, it drained down to the keel and had no where to go. Stupid.
I"m not positive, but I would bet your boat was designed pretty similar to mine as far as drainage.
