I have a hard time getting my 3.0 to idle well much below 900 rpm. It gets rough sounding, kind of lopes along and then eventually sputters out if I don't give it gas. I am referring to my boat tach...which I'm not sure how accurate it is. New plugs, new wires, just recently reset the timing...new fuel filters...relatively new fuel pump...and a few other things.
When I rebuilt the carburetor I was missing a new gasket for the venturi cluster..so I tried to reuse the old one. It probably isn't 100%...but was wondering how critical this gasket is?
Could this also just be a choke setting issue? Even once the engine warmed up, although it smoothed out some, it still wasn't real good at low rpm's
Another thing I'm wondering about is the correct setting for the accelerator pump. There are 3 settings for it & I'm not positive I have it set right. For what it's worth, the boat seems to accelerate fine. If I understand the function of the accelerator pump correctly, this shouldn't really have much to do for just establishing a good idle speed, should it?
Thanks in advance for any advice.....!
