97 merc 40 two stroke grey substance
Duk518
I have a 97 merc 40 hp two stroke that has a grey substance coming from the prop area after I changed the lower unit gear oil. This showed up after running in the driveway with muffs for 10 mins.
fairly common sludge.----Not to worry.----But have your local friendly boat shop do a pressure test on the gearcase if you are worried.
QBhoy
Seen this before, with it being 2 stroke oil residue from sitting in exhaust...especially on a too heavily mixed oil ratio.
you cant load the motor on muffs, so the unburnt fuel and oil become exhaust sludge
Loaded or not loaded.--------Some fuel / oil goes right out the exhaust ports and is wasted !
