????--The " air fill valve " is used for injecting storage oil for long lay-up "----Or for injecting an engine cleaner.-----The red lever is used to manually open the primer valve should you have a dead battery. ---Yes that motor can be started manually with a rope should the battery be dead.-----The red lever should not be moved as an " adjustment " and should be inline with the valve body !!---Please take the time to learn how to use the start / primer function and how it operates.----It is an elegantly simple device that has been used on many motors since about 1980.
