Cricket Too
- May 14, 2003
- 1,732
Hey guys, just pulled the lower unit down to do a water pump on this engine which I just bought. Fought me the whole way, finally got the unit down after standing on it and bouncing a bit to get it to drop, then had to chisel the impeller off the shaft, at least I got it though, guess it could have been worse, considering it looks like nobody has had this lower unit down in 10 years, all pump parts look original 1997.
Anyway, I noticed that the driveshaft has some play in it, both back and forth and up and down when you pull up on it. If you push it back and forth(side to side), it will move about 1/16 of an inch at the base, maybe a little more, in any direction you push, it is way more drastic at the top of the shaft, but that doesn't concern me, since it will be in the crank. If you pull up on it you get about the same amount of play, about 1/16", just feels like a little too much to me.
I've done about 5 or 6 pumps in the last couple of years, on previous boats and on friends boats, and I don't remember there being that much play in the shaft, but I could just be overly cautious or losing it, figured I'd check here before I put the new pump on and stick the lower unit back up.
Thanks, Mike.
Thanks, Mike.
