My 97 Honda wont run full throttle all the time. Its starts and runs fine at lower rpm, once I go to to full throttle I'm only getting about 4900 rpm when I used to get 5600 with no issues and its lost it good holeshot. It starts and runs fine but is now starting to almost stall after a few minutes at idle. But the biggest thing I can't understand is one day it will run fine and idle with no issues, run wide open and get on plane perfect then for no reason drop 700 rpm and start running rough again. Primer ball and fuel lines are in good shape, I also have a kicker motor that is running off the same fuel line and pickup with no issues. Fuel is good as I'm using it quite often and also use stabil or sea foam and run atleast 89 or better ocatane. Any thoughts? All responses appreciated!
