hard to start have to feather throttle after cranking alot. compression test done 135 and 125 lbs 10 pounds difference in cylinders,what should i check????
rotary valve, rings, carberator
tcw3 oil was added by mistake ran 1 day on it an then empty tank and put fresh seadoo oil
