badly bent or broke
- Jan 5, 2008
- 34
I purchased this boat last fall and had problems with it not idling properly. It runs well at other times but sputtered and died with regularity when running at low throttle, less than 2000 rpm. After reading this forum I found out that a rebuild of the fuel pump was probably in order and did that over the winter. On a couple of trial runs in January and February it ran much better at low RPMs and I thought I had the problem licked. Now the problem is back and I am scratching my head and reading this forum to figure out ma solution. It acted like it was starved for fuel or maybe there was water from condensation in the gas. I changed the fuel filter, removed as much old gas as I could from the tank and changed spark plugs but still was experiencing the same problem this week. I thought that air could be leaking around the cable ties that were use as clamps on the fuel lines so I replaced them with hoses clamps and visually inspected the lines for leaks but didn't find any.
Since the fish weren't biting yesterday, I took the cover off and cranked the engine to see if I could see anything obviously wrong. The main thing I noticed was that the fuel filter was never full of fuel as I expected. Shouldn't the fuel pump keep it full when running? After watching it run at different speeds I never saw the fuel filter anywhere near full, much of the time it looked empty with just enough gas passing through to keep it running. Once after it died, I pumped the bulb and noticed gas leaking out of the fuel pump. I checked the screws on the fuel pump and tightened them a little but gas still escapes around the gasket. That gasket must not have been installed properly and is probably causing my problem.
My questions for the experts are?
1) Should the fuel filter run full of fuel?
2) Should I just replace the fuel pump gasket or put in the whole rebuild kit again?
3)Does anyone have anymore insight into this problem?
