Re: 97 Force 120 Max RPM
Re-read the plate. It should say operating range 4500-5500 RPM, 120 HP at 5250 RPM. At 4800 you are in the correct operating range so the engine would appear to be running well, but if you want to gain a few more RPM, then a prop change is the way to go. Drop down 2 pitches to gain 400 RPM--However, with the lower pitched prop, speed may remain the same or even drop a couple of MPH.
