My first outboard, I've had her a year and I'm still getting to know her.<br /><br />I'm seeing water exiting from around the bottom edges of both lower mount cover plates on my '97 Rude 115SPL. Is this normal? I've been tracking an overheat issue I had at the ramp the other day where the alarm sounded after only idling to the ramp dock. I've run it on the hose and in a tank since then and have not had the alarm repeat. The water is slightly warmer than the tank water but not as warm as the discharge water at the outlet, and is coming out in substantial volume. The pee hole is running, but not all that hard. Would this mean there may be a hole in the water tube inside the housing? This may have been taking place for awhile, I just now noticed it.<br /><br />I'm going to replace my impeller, what else can I look at when I've got the lower unit off?<br /><br />Thanks everyone!
