97 2 stroke yamaha 40hp 3 cyl bogging after minute at WOT
wdrennan09
Hey guys new to the forum but I have heard there are some guys on here that have a wealth of knowledge and I need some help diagnosing a problem. C40TLRV 40 hp 2 stroke 3 cylinder will crank on first turn, idle fine for an extended amount of time and open up, get on plain but after about 1-2 minutes running wide open it begins to bog down and will stay like this. However if you come back down to idle speeds for a couple of minutes and open her back up it will run like a top again only to start it again after another 1-2 minutes.
To give you a little background, I am a do It your selfer but very green to outboard motors, however have managed to recently clean he carbs and replaced impeller. Changed impeller bc his summer I was on the MS river ad ran it through some pretty shallow water on san bar and took in quite a bunch of sand, clogged lines and had to clean it out and replaced impeller. Carb and fuel system seemed to be running fine but left ethanol gas in the motor for quite while and decide to clean as preventable maint. I did not have this bogging problem until I cleaned the carb. and changed impeller/clogged it with sand. Also to note I tinkered with the idle screw and reset the air screws on the carb to 1-3/4 turns (factory recommendations) they were at somewhere around 3 turns. I also replaced fuel pump and filter.
I have heard these older motors have a safe mode and run at only lower rpm when they run hot, which Is why I am putting info about the impeller/cooling problem.
Another strange note I have also noticed it does start to bog down like this a couple of times when you turn it real sharp while on plane, May be a strange coincident.
Any idea what this could be ? Any help would be appreciated.
Thanks in advance.
