Re: 97 120 Tachometer is acting weird
Hi stssa,
Yes the corrosion was inside the multi-pin main loom connector, on the back of the motor. The corrosion was on the pin side of the connector at the base of the pin causing two of the pins short out. This was sending electrical interference to the tacho causing it to read high from time to time. Once I cleaned the corrosion off, it worked fine. Luckilly the corrosion was on the outside face of the plug & not inside the wiring loom behind the plug. I would have needed to run a new wire from the regulator to the tacho in that case.
You will be able to look at you service manual to work out which pin is which.
Look along the wires to see if the insulation has any cracks or splits.
On my motor there are 5 connections between the regulator & the tacho.
Working from the regulator.
1. A bullet connector connecting the grey wire from the regulator to the main loom.
2. The large multi pin connector at the back of the motor. Connecting the engine loom to the boat?s loom.
3. Another multi pin connector near the forward controls. Connecting the boat?s loom to the controls.
4. A smaller multi pin connector coming from the forward control to the gauges.
5. The connection on the back of the tacho.
I cant remember where I read an article on troubleshooting boat tachos but it said if the tacho is reading high it will be the result of electrical interference on the signal wire. If the reading is low, the signal is weak (corrosion or frayed wire). If the tacho cuts in and out (especially if the light flickers on & off) it would be one of the power wires to the tacho. This supposes the tacho & regulator are working properly.
I would think the quickest way of finding out if your problem is a short in the signal wire, is to run a temporary wire from the grey wire on the regulator to the back of the tacho & see if this fixes the problem.
Hope it only a wiring problem.
