petermarcus
- Apr 30, 2010
- 129
Good to know, thanks!Ayuh,..... That's a MercWeber 4bbl. which is an exact carbon copy of the Eldebrock 1409 carb,...
Edlebrock parts are cheaper, 'n easier to get, so buy yer parts for the 1409,...
Are you looking to rebuild or replace the carb. If looking to replace vs rebuild i belive an edlebrock 1409 would be a drop in replacementGood to know, thanks!
Ayuh,.... True enough, but reusing the jets, needles, 'n springs from the Oem carb, would bring it back to spec,.....It might have the same CFM but I doubt the 1409 is Calibrated the same as the 9670, when it is taken out of the box
