This ski is bogging out of the hole. Bogs for 10seconds and then takes off fine. I changed plugs and fuel filter. I also emptied fuel tank and put in Shell V-Power. Compression is good at 138 in each cylinder. Is this a fuel pump issue or do I need a carb rebuild? Does Sea Foam help in an engine like this? I have used it with success in my 4.3 liter I/O. Any other quick fixes? If I need a carb rebuild, I would like to wait until winter. Thoughts?
