96 Volvo penta 5.0fl pnca won't start
Tunr4life
Just recently bought my first boat and enjoyed it with no issue for about two weeks. Third time I went out the boat started and ran fine for about an hour brought the boat back in and let it sit for about 30 minutes. When I went to crank it it would turnover but would not start the motor has a Holley 2 barrel carb so in order to get it started I pumped the accelerator pump and it started but died after it used up the fuel. Finally I gave up and had to put it back on trailer. I just disconnected the fuel line to the carb and cranked it I get no fuel. So I'm guessing it the mechanical fuel pump my question is how hard would it be to switch over to electric fuel pump from mechanical if it's possible.. And if anybody would know is there a substitute fuel pump that I can use other than the Volvo one. Thanks for any help
Tunr4life
Yea I think
I'm going stick to the mechanical fuel
Pump I've been doing some research and it's not worth the trouble thanks for the lonks
Ayuh,..... Is this a 5.0l Ford, or Chevy based motor,..??
Are ya sure it's got a mechanical fuel pump,..??
Sparkinator
Bondo. That FL is a Ford 302. My 95 FL is mechanical so I'll bet that 96 is as well.
I found a good price on a marine mech fuel pump at a popular racing parts website. I think it was a carter pump.
Tunr4life
Yea it's a ford 302 with a mechanical fuel pump I'm looking for a replacement that's not going to cost me 300 dollars I see some online but the shaft that goes on the cam lobe is shorter so not sure if they would work
Sparkinator
This is pump I replaced mine with. It bolted right up.
http://www.summitracing.com/parts/crt-m60389
carter m60389
OH10
I had the same issue with my 1998 volvo penta. I thought i had a bad fuel pump to but it ended up being the 5amp fuse was bad. Just a thought.
bruceb58
Mechanical fuel pump. No fuses.
