96 Starcraft Pro Fisherman 190 Wiring issues
numbutt1
Just picked up this Starcraft and Im trying to figure out everything the previous owner "fixed". Hopeing someone with this type boat can give me some insite as to how things were ment to be layed out. Problems Ive found so far... Rear livewell shows no signs of life and doesnt look to be very accesible at all. Bow panel has no power whatsover. Radio has no power whatsover. Both front livewells work but have been rewired so that main controls at the wheel control both. Front controls left, rear controls right. The front bow mount works if tied to a batter(not installed yet). So I guess Im trying to figure out how these things were wired from the factory. Should there be a battery in the bow? Does the main engine typically charge everything or should there be an onboard charging system? Is there a fuse block located somewhere other then the little resets on the main console? Are these rear livewells really as impossible to access as it apears? Sorry for the ignorance up front this is my first "real" boat besides a little 12ft puddle jumper with an outboard on the back. Are there any resources for the layout or something more specific than generic wiring diagrams. Thanks in advance for any help
