96 seadoo xp cuttiing out
thebarge
Just bought this 96 seadoo not used much. Ran great for a couple of weeks. Now at full throttle it cuts out or surges. Just changed the spark plugs but still running the same. Have any ideas?
Jeff Walkowiak
Re: 96 seadoo xp cuttiing out
it is common for that to happen when the internal fuel filters get dirty inside the carbs
thebarge
so new fuel filters should take care of it . or do i need to get the crabs clean?
Jeff Walkowiak
to clean the filters you need to take the carbs off and apart so It would be a good idea to at least change the diaphragms
GeeFrankk
GeeFrankk
Before going internal, clean all external filters, and if your running ole gas or bad gas it will do the same.
B O A T bring on another thousand
