I recently rebuilt the top end of my seadoo gtx. The motor will start when i pour fuel directly into the carbs, but it stalls out. Seems to be starving for fuel ..Any Ideas? Thanks
Yes, The fuel line is hooked to the pulse line. No I did not rebuild the carbs. Is that a must for a top end rebuild? Is ther a way to prime the fuel line to the pulse? Thanks.[/I]
the pulse tube goes from the crank case to the fuel pump on the front carb it is not a fuel line, and it is a common thing for people to forget to hook it back up so you better go check it.
