'96 ocean runner 225 runs and then stops
flubs
After squeezing the fuel ball to a solid state, the motor is started and it will run for about 3 minutes. At this point the motor stumbles and then stalls. Fuel is being drawn directly from a can through the ball to the motor. Fuel ball goes soft. All connections and hoses inspect ok. Oil pump seems to be functioning. Continuous squeezing of the ball will allow the motor to run. Fuel filter is clean. While squeezing the ball I noticed a little fuel drip forming at the "pimer solenoid fitting". Perhaps the o-ring behind the fitting is allowing air in to interupt fuel flow. Any assistance will be greatly appreciated.
Solittle
Re: '96 ocean runner 225 runs and then stops
Welcome Sir flubs - You will get more cohesive responses if you keep all questions relating to a problem to one thread - you have two that I've seen. Helps us to see the overall picture. <br /><br />Our moderator may combine them.
swade28
I am experiencing this same exact problem. Have you had any hesitation from your engine at high speeds, or any speeds for that matter. I am thinking the same thing that air is getting in with the fuel mixture and causing me to have hesitation problems but mostly at high speed when the pressure is greater. Thanks, Scotty
