Hey guys, been searching around for awhile and I can't really find too much. Just picked up a bayliner with a 3.0l mercruiser in it. Wasn't getting fuel, so I replaced the fuel pump fuel filter (inside the bowl) and now I get fuel. Got it to fire up twice in the span of a few minutes, then nothing. Choking it and leaving it in neutral. Won't start, kick, or anything. Just cranks. If I let it sit for some time, it will start up for a few seconds, and then die. Noticed that after I stop trying, there is fuel pouring into the carb from the venturi (?). It will leak for about 10-20 seconds after trying to crank then drip slowly for a minute until it eventually stops. The carburetor was just rebuilt for this reason with a sierra rebuild kit. I'm gonna check float level and see if I can find out how to check the choke (electronic, push button right on the pivot of the throttle lever by the steering wheel). Anything else that I should be checking? Boat sat for over a year until I got it. Thanks.
