Here we go again, 1996 Merc 135 low oil beep beep beep started with the key in the on position but motor not running All oil levels good. Beep beep beep never stopped, parked it. Got home turned key no beep, ran on muffs for 10 min no beep and exhaust appeared to contain oil and more at higher rpms than idle. Replaced battery and beep returned, starting elimination process. Float, motion sensor, warning module, oil pump? Does this sound like module? Seems unlikly to be motion sensor or pump as alarme startes before motor even cranks over. I will follow up after more testing but anyone had similar case or ideas? Also odd that it went away, ran and then I switch battery and it comes back?
