I intermittantly lose the spark on my middle cylinder. Does not seem to be temp. related because sometime the motor starts up bad, sometimes it will run fine all day. I gambled on a new coil since it was relatively cheap. It did not help. Is there an easy way to determine if the problem is the powerpack or the stator? Plug and plug wire is good.
Thanks,
Perri
Thanks,
Perri
