Re: 96 johnson 150 hp help please
Compression test. <br /> Power pack output to coil with peak reading meter, with boat in water in gear all rpms, to insure system ok.<br /> Remove hose to fuel restriction sensor, connect vacumn gage should be close to 4 inches max at all rpms,in water in gear.<br /> Check for arcing between ignition coil and plate that covers power pack.<br /> If you used wiseco pistons and OMC clearence, the pistons may be to tight.<br /> Fuel pressure. <br /> Did you get new VRO pump with rebuild?
