Alright 1996 fast strike 150. Motor will start and idle a little rough at first then idle fine. Does smoke a little to much i think. When in the water it will start and idle when its put in gear it wants to die. If it dont die and you give it throttle it will not plane out and starts bogging down. It will spit air every now and then but all the time.
I have replaced fuel pump, primer bulb, spark plugs and rebuilt carbs. Compression and spark test is good as well. What now?????
thanks for the help
thanks for the help
