96 Johnson 112 V4 spl bogging down when given throttle.
BostonDave
1996 johnson 112 v4
When I start up the boat and put it in gear, if I give it full throttle, it bogs down and shut off I can only go about 4-5 mph however if I start the boat in neutral and have a higher RPMs if I shift it into gear and can now pick up speed without the motor bogging down. Does anyone have any ideas on what this could be?
Honorary Supreme Mariner
Some inspection needs to be done.----A compression test is first.
havoc_squad
Sounds like the transition between idle and full throttle is almost non-existent on the carb(s). Either something is clogged up or they aren't jetted to match the cylinders if they were oversized.
I would have liked to have heard how that idle sounded under load at 800 rpms, but I'm sure the compression test numbers will probably answer that.
