Bill Collector
- Feb 27, 2005
- 79
My GTX was bogging last summer but would clear up after about 15 minutes of floating around in the water and feathering the gas and shutting the engine off and turning it on. I did a pop off test and one of the carbs was leaking and wouldn't hold pressure. I rebuilt them with factory Mikuni rebuild kits and double checked my work. Used the silver springs and also replaced the needle and seats. I took my son out on Sunday and the exact same thing happens. The ski bogs. I feathered the fuel on off switch this time and seems the carbs are flooding causing the bog. I removed the carbs last night, checked the front filter and blew threw the return line and nothing was out of place. I opened the carbs and they look perfece. Going to do the pop off test now. Any suggestions? I also tested the rectifier and from what I could tell on my ohms meter it read 14 V. Would the wrong needle cause this? I ordered the 1.5. <br /><br />HELP!!!!
