markatmfasis
- May 15, 2005
- 7
I just purchased a boat that came with a '96 evinrude 9.9 2 stroke. It is a sailboat so this motor doesnt get much use. It ran very well for a month or so. 2 weeks ago I had it running at high rpm for about 20 min when the rpms suddenly dropped. It would run at idle out of gear no problem. But when I put it in gear I could only slowly increase the throttle or it would stall. I made it back to mooring and realized that I had not opened the vent on the gas tank after filling it last.<br /><br />The following weekend it seemed to run fine. This past weekend, however, it started doing the same thing. I checked the fuel line and everthing seems fine. The filter is clear. I drained the carb bowl thinking that there might be water in it. I then found that if I pulled the choke lever about half way the motor ran perfectly. <br /><br />I am at a loss. Any words of wisdom?<br /><br />Mark
