I have this motor which is baffling me. It runs great but the shifting from gear to gear is out of whack. It may be the shift rod height needs to be adjusted or it maybe something else. I thought to ask before pulling the lower unit off.. I may need to edit my description of the issue as responses are given..I have the manual and have followed the instruction for the remote cable installation. The motor seems to have too much neutral,if that makes sense. Without the shift cable I can shift to forward , neutral and reverse. WIth the shift cable connected I can get forward or I can get reverse. I have tried to adjust the trunions back and forth to achieve normal shifting but have had no luck so far. It is as if there is there is too much of a span in the neutral position to allow both the gears to engage with the given amount of the throw allowed from the control box, hence the cable at the engine end.. A few months ago all was working fine, the boat has been used in the meantime but now this issue has reared its ugly head. If the shift rod height is to high does this occur ? My next step of course will be to drop the lower and check the shift rod then pull the carrier ect out. But as long as I am not getting my hands dirty today I thought I would ask for some insight.
I need to add that prop has been bent as a rock was hit. I dont think this caused the issue but need to mention it. Also I checked the gear lube and it was free of any metal bits, there were none.
Thank you in advance for your responses ,I look forward to them .
