Have a 2 stroke carb'd oil injected dt140, turns over great but won't start, continuous beeping from binnacle when ignition key is in 'on' position, has good compression on all 4 (125+) and spark, cylinders are getting fuel.
Has oil in the oil tank, after getting home tonight from working on, looks like I may need to bleed the oil injection pump, I'll try that next.
Anyone know what the fast continuous beep when the binnacle ignition key is on means? It's not a pattern, just a continous fast beeping that never stops in the 'on' position, with motor not running.
Previous owner was running on 2 stroke mix, I thought motor should at least start. Also wondering if maybe I'm missing a binnacle wiring plug connection somewhere. Anyone have binnacle wiring diagram for the older dt140's ?
Thanks
Thanks
