96 Blazer tow rating
jjjj96
This is a 4.3 vortec 4wd 4 door need to know what it will haul. Have a 6000 lb camper and thinking about buying this vehicle if it will handle it. I'm thinking it won't but not sure any info would be appreciated.
muglydog
Re: 96 Blazer tow rating
Each year Trailer Life Mag prints the tow ratings for many tow vehicles. Maybe you can get a back issue from them. 1-800-825-6861. Some times the tow ratings are posted on a placard located in the glove box. What you realy want to know it the GCVWR. (Gross Combined Vehicle Weight Rating) it is the maximum weight of trailer +vehicle +passengers +gear you can drag around. Maybe the dealer can furnish the numbers you need.
kenh1010
It depends on how often or how far your going to pull it. I pulled a 5600# boat<br />with the same truck and it can do it with<br />out to much trouble. Use a weight distrubuting hitch and have trailer brakes!<br />However 6000# is maxing it out. I now have a full size V8 and feel more comforable. If you plan on pulling long distance or up a lot of hills get a V8.
