96 75 hp force
chad peters
Please someone help, I have a 96 75hp outboard force that will idle fine and run at high rpm in the drive way with a hose but as soon as i put it in the watr it won't idle or go past 2100 rpms anyone have any ideas.
further
Re: 96 75 hp force
Need a little history if possible. Have you had any work done?
chad peters
Re: 96 75 hp force
Took it to a mechanic last year he put a new stater on. Ran fine until memorial day this year took it back he rebuild the carb said it ran fine in his drive way should be good. So ipicked it up and put it in the water and it just wont idle or run past 2100 rpm
further
Re: 96 75 hp force
You say he rebuilt the carb and tested in his drive? Final adjustments after a carb rebuild (i.e. fuel/air mixture, and idle) need to be done in the water with load on the motor. Also need to check timing. Same thing happened to me last year. Motor ran fine on muffs, but would bog down in the water. Do you have a manual?
chad peters
Re: 96 75 hp force
The mechanic does. He said he adjusted everything where the manual said to set. He has got it on the lake now and last i talked to him he can;t get it going. Still sstalls when idle and runs only at 2100 rpm. Could it be the fuel pump.
further
Re: 96 75 hp force
If he's got it set right and it's still a problem, I would check compression, then spark. If that checks out ok, move onto fuel. Hopefully others will chime in too.
roscoe
Re: 96 75 hp force
Not likely the fuel pump.
Sure could be no compression on one cylinder, or no spark.
Don't let him do any other work until he has checked compression and spark on all 3 cylinders.
further
Re: 96 75 hp force
Let us know how you make out.
Thanks
chad peters
Re: 96 75 hp force
He said the second cylinder was shot. I'm done messing with the Force motor, I ordered a whole new engine. Mercury Optimax 75 hp, oil injected, what do you think, is this a good motor?
roscoe
Re: 96 75 hp force
Not a bad motor, but If I could afford/justify it, I would have ordered an E-tec.
