'96 5.8 volvo tilt/trim sending unit
740Schafer
my '96 Volvo Penta 5.8 L has developed erratic readings with the tilt/trim guage and i'm pretty sure it's got to be corrosion on the sending unit located somewhere in the leg or??<br /><br />can anybody direct me to the right location so i can repair this problem?<br /><br />Faria guages and all contacts are clean and the guage is operative, only the indicator is not what the leg position is and it is always jumping around.
Don S
Re: '96 5.8 volvo tilt/trim sending unit
The trim sender is located on the starboard side of the gimbal ring. Attached with 2 small bolts over the pivot pin.
740Schafer
thanks Ken, can it be cleaned or is to be replaced?<br /><br />Randy J
