96 225 update
fishman204
Well after rebuilding carbs and new intake gaskets she sounds terrible.Now I checked the spark with a screw driver ta ground way and its not brite blue and snappy.I really tried hard keeping all parts clean thru-out this process in hopes all would be good.When I strarted her up there were some serious sneezin an coughin.I cleaned the plugs QL82YC which were ruff from all the trolling, no wake zones last season.I also cleaned the battery cable connections as well as the coil grounds.Could this be a pp problem?The stator looks fine No tests were performed though
fishman204
Re: 96 225 update
Also at the end of last season she did not run well either.The fuel was treated but is ethanol crap.I will try a remote tank but the spark still has me worried
boobie
Re: 96 225 update
Go to cdielectronics.com. They have good ignition trouble shooting procedures. You may also want to do a compression test on it.
fishman204
Re: 96 225 update
After looking again I think the stator is starting to melt down.Do I just replace it or the pp too
boobie
Re: 96 225 update
Test everything before replacing. I've seen stators look like that and they still worked.
fishman204
Re: 96 225 update
Arghhh Already ordered.The guy at CDI seems worried bout the regulator now
fishman204
Re: 96 225 update
Now with the mew stator a new problem all port plugs wet,oily starboad dry,sooty but sounds alot better than before and does not shake and sneeze as much
