Re: 96 135HP Mariner
Ken,
Sounds like you're looking for the holy grail... something that is all things to all men.
As far as slow speed running they are as good as you'll get with a 2 stroke. If you need super smooth idle for long periods, get a 4 stroke, or a small kicker engine.
As for skiing, great, lots of bottom end torque. Makes sure you have a smaller (pitch) prop for that though. Skiing puts a very high load on the engine and you get round that by dropping prop size.
Disconnecting the oil injection system.... Why, is it faulty? If not, leave it running. The Merc oil system is the best on the market. Most people who have had major failures with oil injection have owned white engines
. If you disconnect it and run pre-mix you'll make your slow running worst. At slow speeds the system reduces the oil ratio to about 80:1, so you'll have less plug fouling. Run pre-mix and the ratio stays at 50:1, putting more oil on the plugs...
C
hris
