Re: 95 Sea Rayder - lots of noise, but no holeshot power
Clean anything that may be in/on/around the grate/shaft/impeller no matter how small.
Did the reverse gate clear the nozzle in forward?
Also check the front (towards the front of the boat) of the intake grate. Should be flush with the bottom of the boat and have a good seal around the edge. If its sticking down at all or the seal is broken/chunks missing will cause problems. (Both the grate and the mounting plate) Have you removed the intake grate? If so you may not have gotten a good seal when re-installing. Make sure the screws are all tight. I use a little dawn dish soap when installing the seal to make it slide in easier.
Could you see the impeller? Any chunks/dings/rocks?
I can access most of the screws/bolts on mine while on the trailer, however I do have to nudge/slide it back a little on the trailer bunks (loosen but don't remove the trailer ratchet strap) to get to 2 of the bolts. You may also want to have it attached to a vehicle so it doesn't move the weight to the rear and flip the trailer up!
I use boat stands on the cruiser when I need to get under it:
