95 OMC Cobra MFI 5.8L V8
Schleyaj24
I have a 95 5.8L OMC that stalls after running for a few minutes then won't start and the Tack is also spinning in circles and acting up. I've switched out the ignition coil, ignition control module and the pickup coil in the distributor and it is still doing the same thing. I'm at a loss as I'm not sure if it is a fuel pump issue (but why would the tack be acting up) or if it's a loose ground somewhere... any help would be greatly appreciated!
alldodge
Might be the tach is killing the spark. Have you tried disconnecting the tach?
