'95 motorguide GWB52W
puffitu
Hello All
I would welcome any input on my trolling motor which I recently inherited. I am able to switch to forward; working as should, neutral; working as it should but when switched into reverse; it goes into full blast forward. So no reverse at all. Not a big deal as I can ultimately turn the thing around but would like to see if there is some component which needs to be replaced, checked or what have you. Ive tested the potentiometer and it checks out fine. Ive searched the web for info on this particular unit but not much at all to be found, other than the circuit board may be in need of replacement. Thank You!
