Help, I have a 95 Merc outboard that has been running great all summer and fall. I was running wide open when I drove over a small tree branch on the river. The branch splashed water up behind the boat and and my motor sounded like it locked up. After tipping the motor up to check the prop I had water running out of two holes in front of the cover. The motor sounded like it was locked up but after a few minutes it started up. The motor idles okay and will throttle up but only idle in gear. It was dark when I got back to the pier so the following morning with hopes that it was wet electrical I tried it again. It started up and fast idles fine. It runs good slow and will accelerate fine... about 100 yards downstream it sounds like it locks up again and dies. I started it up fine and idled back to my pier. Any suggestions to start troubleshooting this problem would be appreciated. If it makes a difference I run my boat all season up north and the temps have been in the upper 20's here.
