Re: 95 intruder 150 bored to .40 over 60 degree motor
NO, IT will not over heat. remember that this is an outboard that has one giant radiator. When working with a cylinder the amount you bore to is only half that amount per side. If you bore to .040 that is only .020 off each side. make sure you have a .040 over piston in hand befor you have it cut. somtimes it is hard to get a .040 over piston, atleast from wisco.
